Cheap-o camber kits?
  • Thread starter Thread starter 03P5
  • Start date Start date
a lot of honda/acura guys use this type of adjusting (thousands of different brands but they all use the same concept and somewhat design) but these are mainly for getting the camber back into a safe range of specs. street use i guess you could say, not performance/race minded. get the real upper adjustable mounts for that.
With Eibach Sports, does the camber on the P5 change much? My old Accord with H&R sports went negative and wore the crap out of the inside of my front tires, I don't want that to happen when my Eibachs are installed.
I'll let you know next week. I've scheduled an alignment with my buddy on Monday / Tuesday (depending on his workload.)
Just eyeballing it, it looks okay.... not far off at all.
with the spool springs my camber remained perfect al that got messed up was my front toe.
yah, get an alignment done (you'd want to do that regardless when you alter any part of the suspension). have them print out the specs. if they're too far out of specs to fix with the OE parts (i doubt it) then that product may be a good answer.
on another note, negative camber isn't the main culprit to tire uneven tire wear... the toe settings are. check the toe settings if anything.
