I had asked a question earlier about a crackling, crunchy rattle:
"When I lift the throttle, as for a gear change (I have an MT), there's a crackle/crunchy sound, kind of like radio static, but it is there whether the radio is on or off. It is most obvious when the engine is cold and at low speed. Putting the throttle back down makes it go away instantly."
I thought it might be a vacuum leak or leaves on the intake screen, but it is still hanging around, despite cleaning leaves out, so now I wonder if is related to the cat. I hear the sound near the center of the dash, and the cat and its heat shields seem to be located near there in the engine compartment.
Anyone dealt with this? Is it just an annoyance, or does it signal that the catalytic converter's core might be degrading and coming loose?
Thanks.
Thanks.
