so say we both are able to get the sport ecu, where can we get the j-spec intake manifold and is it that much of a difference with the high flow one street unit sells? what does the crankshaft pulley cost and is that an option to go after the manifold
ill call them up tomorrow... asking if the sport 20 ecu is needed to run the intake mani and if theycan get them, if the msp is the same as the dual runner jspec IM and if they offer similar ones if not Jspec
Mazda Intake Manifold
Application: Protege, Protege5, MP3, and MAZDASPEED Protege
Kit Includes:
Vacuum Line
Vacuum Tees
Port & Polish Option:
You have the option to have the runner ports machined out and polished to match the gasket and head for better flow.
The runner ports are machined out and polished as much as possible to match the gasket and head for better flow. Top of runners cannot be machined too much because casting is thin in those areas.
Not Ported 1
Not Ported 2
Ported 1
Ported 2
To run a ZE ECU you need a ZE Wiring harness. It has a special exhaust Temparature sensor. It is OBDI. And Mitsubishi connectors for the ECU. Did I mention you have to modify the ZE wiring harness because ZEs were RHD ?
I talked to SU and he mentioned that you would need to purchase an after market egr pipe for it and the offer it."just haven't looked at it yet" . I've also read that some people tie off the egr pipe so old emissions are not stored back into the engine but sam said that it would trigger a CEL. He didn't know much about the J-spec intake manifold but he did say the hi flow intake mani is the same cast as the 626 manifold. He also suggested to get the car tuned after installation because of the rough idling afterwards and the different vtcs or vics "whichever the lingo is" is off fuel and air ratio. Know I am interested to hear the the Jspec Intake mani- is the same as the 626 because alot of other members seem to already have it installed or if its different after modding the 626 mani- or if its all around a different mani-
I havent but i'm researching what the difference is between a 626 mani and the Jspec manifold. I know the Mani- is priced high but I am more interested in getting the sport 20 intake manifold. If I can't get my hands on that bad boy then i want to find out what is the closest thing to it. And plainly, Im learning and comparing what everything is. I learn by experience then anything else which sucks lol but do you have any insight
if your gonna get anything i would order from protege garage or corksprt, some of the prices may come out to about the same but the customer service you get will be way better and SU doesnt have a very good record with people here
