Can't decide which Header to get
if we can get more details on what's involved with the sport20 setup, i'll see what i can do for ya.
sounds too good to be true. and the verdict is in and i have an hi power HKS axle back so i'm going to get custom piping done. i got one quote and they said 400 450 from one shop with a magna flow cat. the same shop said to install the racing beat would run me 200 so all together would be 650 700 for the racing beat exhaust installed. i went to another muffler shop and they said they'll try to beat the other quoted shop.
since you have the fs-ze motor, the fs-ze ecu is going to be the best ecu for it, like ghostbuster said. IMO go that route. more power and more reliable.
so you think custom piping is the way to go and could you tell me exactly what i should get for the hi flow cat? i already know to get 2.5 tubing but any other modifications?
not 100% on the FS-ZE honestly.
I'd do a 2.5 high flow cat though.
other than that, you COULD do a 626 intake manifold, but, that shows more gains on forced induction setup.
Maybe do some cams? Twiggys if you can find em-(edit-not sure but, the FS-ZE cams may be good enough)
You 100% need to get a FS-ZE wiring harness to use the ECU. It is OBD1, there is no check engine light. It has an Exhaust temparature sensor, and the list goes on...
rocketeer, dumb question, but, is your shifter forward at all?
I test drove my car with the new "JDM"block and my first gear is about at the A/C controls with 2nd gear being where 1st gear used to be
I took it back after the ABS light and ebrake handle wouldn't turn off
ok guys tomorrow i'm gonna see if i can get the wiring harness and ecu, as far as price, to be honest, i dont really care to make a profit, i'll let u know how much these guys want for the stuff and i'll check out the shipping, will let you know, well just to let u know i did a conversion from the 1.6 zm to the sport 20 fs-ze, i dont have alot of info on the difference in the wiring and stuff,i had an auto electrician re-wire it, i got the active-matic(tiptronic) tranny with it. I know of 2 separate guys with full fs-ze's , i.e. engine, tranny, ecu and harness. I actually thought that the fs-ze and de would have similar harnesses since they are pretty similar, having the same sensors and stuff, i even use the fs-de cam sensor and crank sensor on mine.
i actually thought the fs-ze intake manifold was superior to the de intake manifold, something to do with the little black box on top
um if your asking if my shifter feels out of place it did until i put oem shifter bushings and bolt in but that was because my shifter was extremely loose because the bolt previously was some scrap bolt and nut when i had my transmission rebuilt.. other then that experience im not sure sorry
