camber after the drop
stuck
Hey all,
Quick question for any of you who have droped the P5 using the Tokiko HP/Eibach Pro-kit combination. In doing this, is it necessary to use a camber kit to correct the camber, or does this drop not effect the camber? Let me know. Thanx (braindead
i don't think so. i got mine aligned without the camber kit (i'm also on the prokit/hp combo) and the shop got it back to within factory specs.
good to know...i am installing the pro-kit next sunday and will have to get an alignment probably during the week after....
ditto... with the same setup.
after i dropped mine with that setup, the camber and caster were still ok the only thing that was off was the toe. the alignment placed fixed that easily without extra parts.
Just get the alignment checked at a place that doesn't just do it to stock spec and you'll be fine. Camber is no biggie if the drop is just 1.5"
I just dropped mine two inches. Everything was almost perfectly in spec. Our cars drop real well unlike alot of other imports.
Similar Threads and Articles
