Cam Seals problem
1sicspeed
Contributor
2003 Mazdaspeed Protege
I changed my cam seals, timing belt frnt main seal oil pickup oil pan gasket. Valve cover gasket. And now its leakimg from cams seals help please?
actual cam seal? or leaking from the valve cover gasket from the corners of the cam caps closest to the gears?
this ^ you should always put a little RTV between the main cam caps and the gasket on our cars.
It was the cam seal I put the sealant on the corners. Now the main problem is there are scaring on the exhaust cam and cam cap but not on the intake side. Any ideas? Maybe bad cams? Or head?
Was it damaged when you first removed the valve cover or did it happen after the timing belt replacement? Visible wear on the cam lobes is normal
