I don't recomend the MHP. It's diameter is 3". That is way too big for a 2.0 L motor. Unless you are sucking massive air with a turbo. I'm not slamming the people with the MHP though. They look really good with the carbon fiber, but you are going to lose too much torque with a 3" intake. The 2.5" throttle body comes from the factory for a reason, so go with that size. The Injen uses 2.5, so I'd go with that. I custom made mine, if you have the tools, I recomend doing that. Much cheaper too.
