C&D Long term update
hamproof
Don't think anyone posted this yet.
http://www.caranddriver.com/reviews...08_mazda_cx_9_awd_long_term_road_test_wrap_up
Some of their gripes:
1. A couple of pieces of interior trim had to be replaced under warranty after the finish flaked off.
2. Getting the aux-in jack to work required a $223 splitter.
3. The trip computer didn’t provide fuel-economy or range data.
4. The ergonomics for the radio controls needed improvement.
5. The post-factory remote start wasn’t very well integrated and would allow only the driver’s door to be unlocked when activated—annoying when you’re trying to load a legion of people in a snowstorm.
6. The struts on the driver’s door creaked and groaned.
7. Interior rattles occasionally would appear and disappear.
8. You had to unlock the entire car before the power hatch would work.
9. And, while its function and operation were good, the resolution of the infotainment/navigation screen was jaggy and the menus seemed unrefined.
On (2), is only true if you get Sirius as well.
On (3), though fixed in later model, it's too bad they didn't include this for the GT trim in US since other countries do have this info. Maybe if the owner sees 14-18MPG isn't a good thing :)
On (8), it is only true if you are using the smart key to open the hatch. But if you press the open hatch button inside the vehicle, I believe it is not necessary to have all doors unlocked.
On (9), can't agree more. The nav resolution is very poor, coupled with the lock out feature (which could be defeated in other Denso made models for Toyota/Lexus) and overall un-refined menu as reported.
Perhaps 1 additional gripe is having to wait for the power hatch to completely closed before I can lock the doors. I might be wrong on this. Now, when the power hatch is lowering itself, if I press the lock/unlock button on the door, it doesn't do anything other than beep. Maybe if I press it and then it'll remember to lock itself after the hatch is completely closed?? I'll give it a try.
Also, MPG as reported after 40k is 18MPG. I guess they should have driven it in Arizona instead where one can easily get 22MPG w/o trying :P
I assume this is for a 2007 or 2008 (did not read the article) since for #3 it shows range data in the 2009 GT
On (7), that was from the (passenger-side) seatbelt buckle that most of us knew already.
On (1), they seem to be talking about the silver painted pieces - There is a TSB to replace for free.
Overall, the list seems to be right on. I have no Sat Radio or remote start on my CX9. Those electronic integration issues were all addressed in 2009 models. Not sure about the sound quality of Sat radio on 2009, though.
All doors must be unlocked before you can open hatch via interior button. There have been many times when I hit the hatch button, get several beeps, and have to unlock all doors via door switch before I can get the hatch to open.
I also hate the fact that I have to hit the door unlock button twice before I can open hatch with remote. Dumb requirement.
Not sure if everyone knows, but there's a button underneath the license plate lights (GT model) for you to unlock/lock all doors. You can basically press once then open the hatch with the lever.
Also, when operate the trunk via the switch inside the car, P gear has to be engaged.
