Broken 3rd gear x 3
This is the PAR Gearset:
are those Straight cut gears FOCUS ?
First I was just asking about 3rd & 4th
Hello Shane,
We have available a 3rd~4th gear set for the Mazda G-Series transmission
fitted to your vehicle. Like you, many of our customers have big issues
with the gears in these transmissions.
The Mazda G-Series gear sets are actually on special for customers in
the USA during the month of January for the very first time, so your
enquiry has been timed perfectly.
The pricing for the 3rd/4th synchromesh gear option is $1,530 AUD
(Normally $1,700 AUD). We only have straight cut gears in stock at the
moment with helical cut version made on an order basis. The lead time
for a helical set will be approximately 6~8 weeks.
We look forward to hearing back from you soon.
Regards,
Gerard Chan
Precision Automation and Robotics
Then I found out I could get my taxes started so $$$!!
And I asked about the full gearset!
Hi Shane,
We also have the synchromesh engagement 1st~4th gear set for the Mazda
G-Series gearbox on special this month for $3,420 AUD (Normally $3,800
AUD). Included in the pricing is the input shaft and gears. These
replace the same factory parts inside your transmission.
As an option, we can also supply double synchroniser versions of 3rd and
4th gears so that you can have the very best shifting transmission
available. If your tranmisssion is single synchromesh on 3rd gear, the
std Mazda 2nd gear synchromesh can be used with our 3rd and 4th gears.
There is also an option crown wheel and pinion upgrade kit available for
the FWD transmissions. These come in a number of final drive ratios and
are also on special for $1,210 AUD.
If you order the whole gear set and crown wheel/pinion kit together, the
pricing drops to $4,230 AUD, so you're saving an additional $400 AUD.
These kits are all in stock and ready to go.
Regards,
Gerard Chan
Ph: +61 2 9820 1100 Fax: +61 2 9820 1900
19 Saggart Field Road
Minto
NSW, 2566
Australia
I'm assuming I need a quaife in order to do the full set and don't if I only do 3rd & 4th. But I would most likely put in an order for Helical cut double synchro 1-4 and then an extra $$$$ for the quaife??!!
do you guys do shipping for Spain ? it would be a hell of a deal since the Euro its insanely higher than the USA Dollars... i might be interested on buying these to have it when i up the boost and the actual tranny setup im running pops !!!
$5500 motor still owe $1400
$3000 gearset
$1500 quaife
Tax return $5000 maybe
things don't add up!
Single dad 2 kids and bills!
Oh and I need it all in 2 weeks when I put in my motor!
4,230.00 Aud = 3,724.08 Usd = 2,538.48 Eur
so, shipping for spain is posible then ? also,, focus. what exactly would i need to make my tranny bullet proof and to hold what im trowing at it, i want to up the boost more, but want to have a tranny that could hold it.. sorry for the threadjack, but i'll be most likely buying what ever i need for it. and since shane is selling if not mistaken, that's why im asking these questions. sorry Kooldino if you don't mind me asking these in your thread..
dog box for crossover? get it if you got 4k =)
Quife: $ 1,525.00
ARP LSD Blot Kit: $ 175.00
Cross Dog Box $ 4,000.00
$ 5,700.00 + Who knows how much Shipping to Spain..
Labor is not a Problem, my all time best friend owns a Shop in here, so labor its Freebie !!!
Quife: $ 1,525.00
Shipping to Spain, should be $200 or less...
yea but dog boxes are the s***
Yes and no, they wear out extremely fast. Great for racing only.
but, do you need to send then your old tranny ? or how does it works..
No, they send you all the parts and you assemble yourself.
Par can make any type of gearset. Helical, staight cut or combination of the two. They also can make dog engagement gearset.
I'm not the one selling I'm buying and I just received these emails from PAR today.
I'm still at a loss what to do! I am only looking for just over 300whp! My 3rd clanks so I'm avoiding it and my 2nd gear synchro is out and my motor will be coming soon I just want a solution by when I'm installing my new motor! Pricing is a little higher than the $2800 I was expecting since now I have to add a quaife to it!
Does PAR offer any kind of warranty on their gearsets? I'm on tranny #3 now (chewed through GTX gears even) so I need a replacement...
Hello Shane,
Regards,
Gerard Chan
Hi Shane,
Regards,
Gerard Chan
Minto
NSW, 2566
Australia
I'll have to call these guys.
Too much money for me, well at least the LSD screw that I'll get a new welded mazda one.
What gears are they, what makes them better than stock. Whats the helical one, isnt that what people say is better? I need inormation people!
think I'll change out 1st-4th when/if the time comes along with new LSD. If I ever get that far with this car.
Aircraft grade tool steel and the teeth are wider. Helical cut is the same as stock. Straight cut is what they have in stock but they are loud as hell! I'm still waiting to hear back whether I can just do 3rd & 4th straight cut since they have them now with the welded LSD.
