Mazdaspeed2oo35
600whp - 600wtq at 30 PSI
This is the PAR Gearset:
are those Straight cut gears FOCUS ?
First I was just asking about 3rd & 4th
Hello Shane,
We have available a 3rd~4th gear set for the Mazda G-Series transmission
fitted to your vehicle. Like you, many of our customers have big issues
with the gears in these transmissions.
The Mazda G-Series gear sets are actually on special for customers in
the USA during the month of January for the very first time, so your
enquiry has been timed perfectly.
The pricing for the 3rd/4th synchromesh gear option is $1,530 AUD
(Normally $1,700 AUD). We only have straight cut gears in stock at the
moment with helical cut version made on an order basis. The lead time
for a helical set will be approximately 6~8 weeks.
We look forward to hearing back from you soon.
Regards,
Gerard Chan
Precision Automation and Robotics
Then I found out I could get my taxes started so $$$!!
And I asked about the full gearset!
Hi Shane,
We also have the synchromesh engagement 1st~4th gear set for the Mazda
G-Series gearbox on special this month for $3,420 AUD (Normally $3,800
AUD). Included in the pricing is the input shaft and gears. These
replace the same factory parts inside your transmission.
As an option, we can also supply double synchroniser versions of 3rd and
4th gears so that you can have the very best shifting transmission
available. If your tranmisssion is single synchromesh on 3rd gear, the
std Mazda 2nd gear synchromesh can be used with our 3rd and 4th gears.
There is also an option crown wheel and pinion upgrade kit available for
the FWD transmissions. These come in a number of final drive ratios and
are also on special for $1,210 AUD.
If you order the whole gear set and crown wheel/pinion kit together, the
pricing drops to $4,230 AUD, so you're saving an additional $400 AUD.
These kits are all in stock and ready to go.
Regards,
Gerard Chan
Ph: +61 2 9820 1100 Fax: +61 2 9820 1900
19 Saggart Field Road
Minto
NSW, 2566
Australia
I'm assuming I need a quaife in order to do the full set and don't if I only do 3rd & 4th. But I would most likely put in an order for Helical cut double synchro 1-4 and then an extra $$$$ for the quaife??!!
4,230.00 Aud = 3,724.08 Usd = 2,538.48 Eur
dog box for crossover? get it if you got 4k =)
yea but dog boxes are the s***
Quife: $ 1,525.00
ARP LSD Blot Kit: $ 175.00
Cross Dog Box $ 4,000.00
$ 5,700.00 + Who knows how much Shipping to Spain..
Labor is not a Problem, my all time best friend owns a Shop in here, so labor its Freebie !!!
but, do you need to send then your old tranny ? or how does it works..
Hello Shane,
Regards,
Gerard Chan
Hi Shane,
Regards,
Gerard Chan
Minto
NSW, 2566
Australia
