crazyspeed6
- Mazdaspeed 6
I used everything that came with the gauge. That tubing is a b**** to get over those T's, but I just took a little heat to it and it strecthed over the T a lot easier. As for the gauge, mine reads a little below zero in the "on" position also. Prosport said it is because some cars create a vacuum because of the accessories. Now I dont know if that is true or not, but my boost readings are just about dead on, so I think it is normal. But my boost readings were 15 to 16 before the standback, not 14.5. I zip tied all of my T's, filter, and sending unit to be sure I had no leaks. That is the only thing I can think of, besides the BOV. I would think the BOV leaking would cause a much worse leak to where you probably wouldnt even be able to get to 14.5, I dont know that for a fact either though. Good Luck.
