boost gauge
06 MS6/03.5 MSP
anyone with a mechanical boost gauge. what vac hose did you tap into?? im looking to do this asap. i could do it from a vac line off the intake mani that goes to the bov but i'd like to see if anyone else found a better place yet. thanks for any help in advance. greatly appreciated.
thats what i was going to do, but i figured there would be a better way. i don't like to tap into the bov line this way it has its own direct vac source. when i had my 93 talon, a thread on a dsm forum discussed how that tapping into the bov vac line can lag your bov from opening, which obviously isn't good.
RevLimitLaunch said:
bump, where did you route your boost gauge line thru on the firewall?
I just ran a long thin screwdriver through the rubber grommet on the firewall to put a small hole in it. I then ran a 2" long plastic sleeve 1/4" wide through the grommet. Once that was done, I fed the line through it.
yeah i know that. now i just gotta wait for the prosport (first)
where did you tap your wires into?
I tapped into both of the cig. 15amps fuses.
mrmister said:
Do you happen to have a picture of where you hooked into for electric.
Thanks.
I used two fuse splitters in the cig locations.
I am using the VEI gauge so I do not use the dim feature. I ran the power 12v wire to one and ran the wire for lights to the other cig fuse.
