Boost controller, any recommendation??
I just took off the forge and installed turbosmart. I wish I had this bc when i was at the track. Thing holds bitchen. I was falling about 2psi before and now it holds solid as a rock.
gotta pay to play... :)
for 300 i got the BCD, and the profec b spec 2. the profec b spec 2 has a boost display, so that helps.
i may or may not take out my prosport boost gauge, it all depends where i decide to mount the profec.
grrr i want an mbc, but dont have money for a guage or bcd
you can do it with just a MBC... i would not but you can.
just install the MBC and turn it up little by little until you hit fuel cut in 4th gear. that means you hit 18psi. then just back it off a little. you will be at 17psi and have no need for the BCD, but you can add it later for an extra few pounds of fun !!
