I just took off the forge and installed turbosmart. I wish I had this bc when i was at the track. Thing holds bitchen. I was falling about 2psi before and now it holds solid as a rock.
you can do it with just a MBC... i would not but you can.
just install the MBC and turn it up little by little until you hit fuel cut in 4th gear. that means you hit 18psi. then just back it off a little. you will be at 17psi and have no need for the BCD, but you can add it later for an extra few pounds of fun !!
