bolt pattern for rx8
mazda_dan
2008.5 mazdaspeed 3
i need to know if the 2003 mazda protege bolt pattern is the same as the
rx8. i have some winter tires for sale and someone is interested in the tires for his rx8.
I am pretty sure the stock pattern is 5 X 114 +45 offset. What size rims are they. 17's fit, but most 16's will not clear the brakes.
the wheels exchange, centerbore is the same.. plenty of guys have the RX-8 18s on their speed proteges. i thought the RX-8 was a 50 offset stock... but I'm not gonna argue with solidtrance! lol
You are both right about the offset. I stand corrected, thats what I get for trusting my faulty memory.
Bolt Pattern - 5x114.3
OEM Wheel Size - 18 x 8
OEM Wheel Center Bore - 67
OEM Offset - 50mm
OEM Wheel Weight - 22.5 lbs
OEM Wheel Center Bore - 67.1mm
OEM Offset - 50mm
one very small semantic correction... which I wouldn't post unless there was an off chance someone taking wheels to a machineshop ended up SOL beceause of a .1mm difference...
