Blown engine!!! MSP down
the oil came on as i was slowing down... i put it in gear to see what would happen, it wasnt good so i took it out. i turn off the car the rest of the way as i stopped.
Joep FCD? 90% of the blown motors on this forum have come from people using Joep FCD & MBC. Hmmmm. Wonder if people will see that it's good to pay more instead of having to rebuild a motor.
i cant agree more.... if you dont want a blown motor on your msp DONT use the fcd!!! the cut is there for a reason......think about that.
i must agree i dont think i would have blown it without it. yet i never researched it... i kinda just went by a few peoples word and got tired of hitting the awful fuel cut. not much i can do now, so im not going to point fingers.
few pics of some damage. as far as i can tell for the night.. im throwing up rods. (puke)
At a minimum, it's going to be several hundred $$s for a new motor (that's for used) & then a LOT of work to pull yours & put the new one in. Then you can either turn down the boost & be smart about it or build up your motor if you plan on making more power.
MINIMUM COST:
new motor: CHEAPEST: $400
swap by a shop with new motor $900
Misc: $300
$1600- and thats the absolute cheapest.
well i'm curious then what is the safest boost(safe boost, oxymoron eh?) to run. i used to have a t-bird turbo coupe and could run 15lbs consistontly no problems. oh by the way this is my girls tag i'm just currious.
03mazspeedproto said:
intake, 10.6 psi, 2.5" DP open cutout, FCD, clutch and 9lb flywheel. thats for the engine..
god there is so much stuff running through my mind right now. i can only imagine what the cost will be.
FCDs suck if you do not add fuel when they comes on. Think about what goes on. The pcm is shutting down the engine so you do not blow it up. The FCD is blocking or reducing the MAF voltage from the PCM. It will send a lower signal to the PCM, so it thinks that there is less air flow. Now it is giving less fuel so you lean out. On Deans car we have an electric cut out. When we open it up we run the 'B' map on the MPI. It is a richer fuel curve that is needed for the open exhaust.
Some may be able to run more boost if things work out with their setup, air temps, what gear they are in. But because you are playing with fire, sooner or later things go very wrong. You more then likely sent a rod out the side of your block. If the bent and the bottom of piston hit the counterweight you need to check a few things. If the pin boss on the piston is gone the piston may have ran up and hit the valves on that cylinder also.
agreed, unless you have something to control the fuel the only thing those FCD is any good for is blowing the motors :(
yeap. teh suck :(
oh and tekkie, we're gonna have to meet up sometime after we both have our stuff installed
Pat for sure :) I have not even started yet, I am going to start looking for a block tomorrow ;)
damn dude :( get ahold of Maurice, he may be able to help you out with a build or just swapping in a used motor and keeping costs down. goodluck
not to thread jack but if you were running some kind of FMU would it be safe to use an FCD? I have a joeP FCD and havent been able to get it to work but im curious if I should even bother because every engine I see go has had a FCD.
(ITS DANGEROUS PLAYING WITH FCD's )
The FCD is any device that prevents the stock ECU from cutting fuel to the rear rotor when the boost exceeds a preset boost level. This maximum safe boost level and behavior is coded into the firm ware in the engine management unit and can not be changed without reprogramming the ECU. The maximum allowed boost pressure is about 7psi in the Protege. The way an FCD defeats the fuel cut is by lying to the ECU about what the boost pressure is. The FCD is placed between the boost sensor and the ECU where it modifies the boost pressure signal by some amount so that as the boost pressure rises above the preset "safe limit", the ECU continues to see a signal that is below the limit. There are a couple of immediate consequences to this fooling around. As the boost rises, the ECU must increase the amount of fuel being delivered to the engine in order to maintain safe and efficient operation. As the FCD starts lying to the ECU, the ECU will begin to under-compensate for the rise in pressure leading to a gradual leaning of the air-fuel mixture. The amount of error increases as the boost rises. For relatively small errors, the only penalty is efficiency. As the error gets larger, however, detonation becomes likely, exacerbated by the high boost pressures and accompanying high intake charge temperatures. Detonation under these conditions will quickly kill an engine. So, before we go any further, be forewarned that using an FCD and increasing boost pressure without also compensating for the ECU error with fuel enrichment (and preferably more efficient intercooling) can cause serious damage to your engine!
