Speed_Racer
- 2003 Mazdaspeed
seen that before, except I also found both my rod bearings. all that on a stock car, wow. looks like mazda rods get shittier with time.
50k miles.POSEIDON said:I thought the warranty ended at 36k.
You seriously blew the ever loving s*** out of that engine.
Hellnightkid said:I thought many ppl blew their stock motor before?Anyway
I dont think mazda will cover this sht...they gonna say the engine mounts blew the engine???lol
They will even ask u all the oil change paper works and maintenice..
My STOCK motor blew at 3800 miles...Explain the bad maintenance there...I also Ran 89 on 12 PSI for a long time....If the ambient was 80 degrees or less with never a problem.....mine didnt blow apart like that thing did though....(boom07)spacemonkey said:You cant blow your engine on stock setttings unless you drive like a idiot.
maybe it was bad maintence? poor oil or bad tank of gas? Looks pretty dramatic to be anything stock.
ForceFed said:My STOCK motor blew at 3800 miles...Explain the bad maintenance there...I also Ran 89 on 12 PSI for a long time....If the ambient was 80 degrees or less with never a problem.....mine didnt blow apart like that thing did though....(boom07)
You think what you want but that motor was not detonanting...and I never ran 89 if it was warmer than that....I was making a point that BONE STOCK motors do blow...Mine looked nothing like that and actually still ran to pull it onto the towm truck but it was toast...Motor and turbo were both replaced...I do beleive I had the first "OFFICIALLY" blown MSP motor on this site...But I do agree...For most cars @ 12PSI would have problems...My car was a bastard child..The second motor had manymiles on it....30K with upped boost....Yes they last and dont Just blow normally...I agree and never tried to say otherwise..pretty much I totally agree...With the exception of your opinion on the fuel.spacemonkey said:WEll Im at 48,000 miles on stock engine and tranny...explain that if the protege motor is so prone to blowing up at stock setting. im not the only one that have reached 40,000 miles problem free. 5,000 units made and how many have blown motors and tranny? The local Mazda dealer ship has probally done like 2 MSP motor swap and that was the same person who drove like a idiot.
You can run lower octane if your out of boost...but your telling me its okay to run 89 octane at 12 PSI with ambient temperature of 80 degrees on a motor with 9:1:1 compression? and on a fuel system that can flow enough on stock injectors to go past 12 psi at redline. Remember what unichip/pinapple racing said about our motors and why they decided to program the EMS to spike at 12 psi and bleed to 9 psi towards redline? You must have been detonating like crazy at 5,000 RPM if it holds 12 psi to redline on 89 octane gas. a good boost creep or minor spike and their goes the motor.
