Big Brake Kit
MSPDetroit
03 MSP Black Mica
Anybody know if Brembo or AEM Big Brake Kits will fits on the msps?? or if they will be coming out w/any for our car??
perf, do the calipers have dust seals for the pistons, therefore letting them perform longer w/o needing a rebuild?
tell you the truth i dont know. will find ou tommorow for you. I have to go to the office tommorow and see the specs on the calipers.
No No, Im talking about mounting. We have larger rotors then the P5 and Sedans. :D Im curious if they will fit. Stoptech gave me a kick ass deal on the price. :D
The stoptech kit will include new hardware for mounting the calipers. The rotors fit perfect. The kit they have is a direct bolt on.
Perf...Do you know if Stoptech makes a bracket adapter to allow use of stock MSP rotor and a 4 or 2 piston caliper?
-Alan
-Alan
Two things Number one your spring will be sent out today
Second, the kit they make is for upgraded front rotors , calipers, pads and ss lines to replace your factory rubber.
They from what i understand dont have upgrade rotors and such i will find out if they do. I wouldnt even think about increasing power and trying to keep the stock rotors and just getting calipers. The stock units fade badly under harsh race conditions
sweet....yeah i was just looking at a alternate braking options...i've got a set of P5 wheels that i use everyday and wanted to have a big brake kit and still use those wheels...i'm hesitant to go with a 13" rotor since that means i'll have to use 17" wheels for everyday and race tires.
same here. i just took my P5 wheels to have snows mounted on them for my car and was thinking about these http://www.rr-racing.com/bigbrakes.htm but wasn't sure if there were more suitable upgrades. i'm already starting to get a slight vibration when braking somewhat hard at higher speeds.
I have 15" wheels for winter, and that's what's stopping me from getting my big brake upgrade. =/ RR racing's kit won't fit behind 15" wheels, not to mention any kit that makes the rotors excede 11 inches, which gives the standard four inch clearance rule for the calipers/rotors. Basically, what I'm looking for is an upgrade that keeps around the stock size, 10.5 - 11" or so, and has some nice 4 POT calipers, but no one has yet to offer these, so I'm screwed. =) Ahh, well. I need to see if I can get someone to make me a caliper bracket adapter for a set of Willwood calipers or something, I guess, and just keep the stock sized rotors.
