Appreciate the help on this matter below and I'm kind of at a loss for what is going on. I've been trying to diagnose this for the last 2 months and I think I have finally been able to reproduce the issue, but no idea what is the cause.
The following errors popup:
- Smart Brake System Malfunction
- Forward City Brake Support Malfunction
This is reproducible if I turn the lights to Auto and just wait. I can speed the process up by having the lights on auto and turning on the heat, heated seats and/or steering wheel, or using the cigarette burner. Basically anything else that I turn on to suck more energy out of the car, the quicker the errors come on. I can be sitting still and these two errors will come out.
Errors will not come out if I do not have the lights to auto.
So the diagnostic things I have done:
- Brake switch/stop lamp change. Exchanged twice... still same issue.
- Changed 12V battery. I have noticed that the battery is at 12.7, but as soon as I plug into the car, it drops to 12.4 (wondering if there is a load on it, even when the car is off)
- Checked the brakes. All the brake pads were recently changed (prior to purchase actually) with good wear. Everything sliding well and without issue.
- Battery will drain over the course of 2 days from 12.5 resting to 11.9 resting.
Other notes:
- Errors initially started on a trip. No car wash. Not after rain.
- Engine throttles a little bit (like going into sport mode) when the errors are on, but otherwise no issues with braking, parking brake or any function.
Appreciate any insight.
thanks
Other notes:
thanks
		 hmmmmm, IIRC, I've seen a post or two about issues with the little motors that control the adaptive light swivel failing. I recall they talked of being able to hear a "buzzing" noise coming from them.
