Best place to access cig lighter wire?
canadian357
2003 Protege5, 1987 Honda Accord Type-R(rice)
I'm trying to tap into the cigarette lighter wire so I can wire up my cupholder LED's and console USB ports. What's the easiest place to find it/tap into it? I'm trying to do it with as little disassembly as possible because I'm a lazy ass.
If you take off the little panel thats on the left side of the passenger foot well, you can see the wires from there as well.
I just tapped into the switched 12v wire on relay coming off my deck (tricks the deck so I can dial and use the nav controls while moving). However now the deck is now not turning on and my keyless entry remote isn't working either. Multimeter shows no voltage going to the relay (it doesn't click when it should be activating either) or the deck, however I checked literally every fuse in the car and nothing is blown. Not even the fuse in the back of the deck. Riddle me that!
