Long time between posts...
I've been enjoying the car over the last year and bit doing a ton of driving in it. In terms of modifications, some of you may have been keeping up with my posts on Facebook but here is a list;
-Installed the Dakota Digital gear sensor
-Installed XYZ 6 Pot brakes with 355mm rotors
-Solved the ABS issue that was driving me nuts
-Installed a Clarion Double DIN GPS head unit with reverse camera etc.
-Installed a new amp, sub and speakers. (made a custom boot install)
-Installed JIC helper springs to the rear coil overs
-Re-installed the charcoal canister
-Rewired the fuel system
-Made a custom front end to help with cooling
-Ducted the transmission cooler
-Cleaned and replace dodgy fuel injectors
-Found a replacement GPS dome and sprayed it myself.
What's next?
-I'm about to move on to doing ALL of the suspension bushes. :/
-I bought a 3500RPM stall converter. Time to install it
-Additional trans cooler
I'll post some images of the upgrades shortly.
