BC Coilover Setup: Compression/Rebound Settings, Ride Height Adjustment, Camber, Etc.
i just made these adjustments to the rears this weekend. I also adjusted the fronts to match as well.
rears before
rears after
before
after
Looks good. I think I might go with your before setting. Looks to be about 2 threads left on the bottom.
the low offset will play mind games with you when comparing to a stock setup. The distance that the stock wheel sits in and away from the fender gives a "more wheel gap" look at the same height,than a setup that is closer to the fender. Did that sound really confusing or do you all understand what im trying to explain.
Ferdball, thank you for the kind words, and your just going to have to make a few adjustments till you find what works best for you. This will be my 5th adjustment and when HIN is over ill probably put it back up a little. good luck
on 18X8s?
wow i feel like i am asking a lot of questions.
Yes. Here is all the info about my suspension/wheel/tire setup I can think of off the top of my head.
BC coilovers, 1 5/16" lowered F, 5/16" lowered R
COBB rear sway
18x8 +40 BBS LM
215/45R18 Bridgestone Potenza RE050A
No fender roll and no rub so far. I wanna bring the rear down some more to match the front so I might need to roll. We'll see.
I appreciate your patience.
you can tell I am really researching this huh?
Sag
LR - Initial
LR - 3 days and 80 miles later
LF - Initial
LF - 3 days and 80 miles later
These are slightly different angles and distances, but they look completely different. Even the portion of the shock looks different. In the front pics, you can see the collar nuts, where initially you couldn't.
Dampening
I got the Left Rear dampening adjustment knob in. But how in the hell are you supposed to get the Right Rear in? When the extenders come in, do I have to uninstall the rear shocks to get them in?
To get to the right there, I just open the little cover near the light and stick my hand in there to adjust the knob.
I don't have Popeye forearms, but unless I unpop every little tab and snap, I can't get in there. I was able to drop the knob into the hole, but I can't get it to grab onto the adjustment threads. I think there is a sheet of metal on the side which may force it to go down the hole at an angle, instead of straight down. The thing was about to cut my forearm off, so I gave up. I hope the extenders help.
Huh? You don't have to remove the adjustment knobs to install the rear shocks. It does take some contorting, particularly on the passenger side to get your hand to the knob though.
