battery light on
P.O.E.T.
my battery light will turn on every time i start my car and it would turn off after 5 minutes of driving, i thought my battery was bad i took it to autozone to check it and there was noting bad with it.....is there anything else i should check?
Alternator? Belt could also be slipping when it is cold, causing it to not charge as much till it warms up and grips better, either due to a worn belt or sticking tensioner.
alt is about to die.......motors(aka the alt) can get off to rough start but after a bit might loosen up......
im not an expert on mechanical problems but i know that my rpm shouldn't be at 1000 when im on neutral.........i have a manual p5.....why is my rpm so high when im not even driving???
