2024 CX-5 CE TPMS Light On
Today the temperature is very low . When I turn on the 2024 CX-5 CE and drive just a while there are some beeping sound and the TPMS light is on . I check all the tires , they are all good. I Could not find the TPMS RESET button. What can I do to reset the TPMS light ?
My 23' is the same. Gets cold and the light turns on. Check the pressure and it is fine. Nitrogen filled also so... No reset I know about. Self learning.
Does the TPMS warning light flash when you turn on the car? If it does then it indicates a fault with the TPMS system, like a bad sensor.
The TPMS just light on not flashing. After about 20 minutes driving the TPMS automatically turn off ! Maybe the weathers so cold
If it corrects itself later, no need to worry about it.
Wireless is not 100% reliable all the times.... interference, etc.
From the 2024 owners manual:
Also, an illuminated TPMS warning light, resulting from the tire air pressure dropping due to cold ambient temperature, may turn off if the ambient temperature rises. In this case, it will also be necessary to adjust the tire air pressures. If the TPMS warning light illuminates due to a drop in tire air pressure, make sure to check and adjust the tire air pressures.
After adjusting the tire air pressures, it may require some time for the TPMS warning light to turn off. If the TPMS warning light remains illuminated, drive the vehicle at a speed of at least 25 km/h (16 mph) for 10 minutes, and then verify that it turns off.
This just happened to me. My 2024 CX-5 is different than my 2017 6 which has a button to turn it off. I had to put air in it and they were down to 28/29 lbs per tire. Filled them up and the light went off. I guess there's no button to push on these.:unsure:
