Battery Drain Issue Special Service Program "NEW"
  • Thread starter Thread starter 34403
  • Start date Start date
3
34403
Mazda has recognized that the 2023 CX-9 and CX-5 (Canada) has an issue with it's Remote Tuner module and software associated with it by the manufacturer of the unit.
These Remote Tuner modules were built with outdated software and therefore the power shutdown processing of the module may not be completed.
In this condition if the vehicle is left unused for a certain amount of time the battery may discharge and run flat.
The Remote Tuner module controls the audio signal from the entertainment system.
Owners of the effected models will get notifications soon or by end of April 2023 if not already about this Special Program where a small new file must be re-loaded by a USB Flash Drive. Please do not contact your Dealer yet, wait until you receive your letter of confirmation from Mazda.
Basically this includes CX-9 and CX-5 (Canada) made from start of August 2022 to present and also includes some 2023 Mazda 3, MX-30 and CX-30 (not for 2023 North American CX-30).
Obviously all free of charge, this update is done via a USB Flash Drive (hardware) and a small .kwi file with appropriate standard of updating via a guide. This update only takes about 7 minutes once USB Drive is inserted.
Your Dealer should record on a label fixed under the cars hood or bonnet (some use door jam) which records what when and where and by whom (Dealer).
Now the Reason I am posting this thread is to inform you guys of a pending letter and action by you the customer. I have copy of this new .kwi file and procedure to update but I am reluctant to issue to owners as in this case your Mazda Dealer should be the first port of repair as you are being contacted directly by Mazda.
Plus, I know a few of you guys have been having Battery drain issues where the cause of has not been found until now.
Having said that IF after awhile you don't get the letter from Mazda concerning your cars Remote Tuner update file booking with your Mazda Dealer then I am prepared to issue you the file to do update yourself, again it is a similar process to updating Mazda Connect firmware.
For some reason Mazda USA is not including the CX-5, this maybe an oversight or that these CX-5s in USA did not have this particular Remote Tuner unit.?
If anyone in USA with a 2023 CX-5 received a letter from Mazda NAO on this issue please let us know.
Thank you for offering to provide this to our members, @ASH8. It is very much appreciated!
I have both a 2022 CX-5 and a 2022 CX-9. Both are very late 22s built in 6/2022. I am a fanatic about battery health using a trickle charger in the garage and monitoring SOC using a battery tester every week or two. Both cars are garaged. They have low mileage; the CX-5 is at 4700 miles. This week, overnight after a 10 mile commute the battery on the CX-5 was completely dead. Measured 4.2 volts and nothing came on. Could generate a weak hum from the seat motor. Had a hard time jumping it........ surprisingly it is showing decent health at 470something CCA and 6.x mohm internal resistance. Comparatively, the CX-9 battery has 5.x mohm resistance and slightly higher CCA rating. I was surprised that the battery recovered so well, but I guess it's because the lead sulfate was not allowed to crystalize. The CX-9 is treated better since only I drive it. If I take a short trip, I make sure that the coolant gets up to temp and will idle it at 2000+ rpm until the needle is firmly at 90C for a few minutes.
So, the PDF (thank you so much) shows the firmware for the CX-5. I guess that it would make sense to check that I have the latest firmware and if not to download it and install. So, they are saying that cars built in 8/2022 have the problem but not so for cars built in 6/2022? Does not make sense to me. And CX-5s are not listed but for some reason the firmware is listed in the document. They stick the same equipment in all these cars. I think that I saw somewhere else that there was a recall for 2023 CX-5s in Canada.
Is there any specific procedure for creating USB drive with update files?
I've tried to download ".kwi" files form the links provided in the doc, and simply pasted those into the formatted USB flash drive (FAT32), but my Mazda can't see update files there when trying to update software in Diag mode. Did anybody has same issues or know how to fix it?
Since my May 10 inquiry, I have confirmed that my cars (6/22 built CX-5 and CX-9) do not have the updated software but I of course do not know if they have different RTs than the 2023s, which were built starting 8/22. I have not had any further drainage incidents. Only had the one on May 10 for the CX-5.
Some countries like Japan and Australia do not use model year like in the US, but go by the build date, so model year could be viewed as being somewhat artificial. Especially for the CX-9, which was built for only a few months as a 2023. In fact, I think the original plan was not to have a 2023 CX-9. Would they really have sourced a new RT unit for these final cars?
I think trying to install the updated .kwi file might be too risky, or what do people think?
