Balancing after Lowering? (Springs)
KurtMP3
Alignment/Balancing after Lowering? (Springs)
Im putting Spool Springs on this week or next - i know i have to balance after i lower the car but my question is should I drive the car for a week or so lowered to let the car setup and then get it balanced or should I put the springs on and immediately balance the car the next day?
Thanks in advance for any advice
Kurt, if there is immediate misalignment, then i'd go for the alignment right away. if not, then let the springs settle for a week or two and then align it. b/c it's a FWD, a two-wheel alignment is all that's necessary. if you're paranoid and want to make sure everything is ok, go for the 4-wheel alignment.
balance is what you do to tires after you just mount them on a rim. You add little weights on the rims to balance it out... yeah you need alignment.
(yes)
Similar Threads and Articles
