Well I am new here and recently purchased a used 2007 Mazdaspeed 3 with approximately 80k miles. To take all the precautions I have already, changed the plugs, oil, transmission flush, radiator flush, cleaned out the EGR, checked the turbo for any shaft play (happily very minimal side to side , checked the transmission for any bad syncro, all the gears seem in good shape and so on and so forth.... Things were going well, we could tell that the car had been previously modded from poor installation of the OEM parts... Anywho, the last step was to check the compression of each cylinder. I am not sure the order of the cylinders right now since we finished this late last night, so going in order from right to left (im assuming cylinder 1 is on the right)
Cyl 1: 190
Cyl 2: 185
Cyl 3: 155!!!!!!!!!!!!!
Cyl 4: 190
As you can see Cyl 3 is very low and has me seriously worried, my first thought is piston rings that are fried...
I am curious to see if this specific Cyl is common for losing compression and how terrible this is, also to see if there is any other possible problems causing this.. I understand without getting in there and taking a look its hard to tell, im just trying to gauge what i am in for.
Is this compression dangerously low or something common with higher mileage engines, and am i worrying too much? Any help, advice or assistance would be greatly appreciated!! Thanks Guys sorry for the long post.. and i apologize if there is a link or sticky explaining all this, i could not find one.
Cyl 1: 190
Cyl 2: 185
Cyl 4: 190
