Actually your info is completely false. Please quit spamming multiple threads with the same post complaining about your problem. Sorry you are having trouble, but your problem seems to isolated. I have over 40k on my CX-7 and no problems. The AWD system is actually one of the best in its price range, excellent system. This is how it really works:
Here is the explanation right out of the Mazda training manual:
"The CX-7 is equipped with Mazda’s new active torque split all-wheel drive system, which
debuted on the MazdaSpeed6, featuring a more aggressive transfer of torque to the rear
axle in accordance with driving conditions. This intelligent system achieves a satisfying
balance between the interactive control over the vehicle that makes it particularly enjoyable
to drive, and confident handling stability necessary for snowy, wet or other uncertain road
surfaces/conditions; engine power and torque are faithfully and efficiently transferred to the
road surface for maximum performance.
The active torque split AWD system uses real-time data input on steering angle, yaw rate,
lateral G-force and engine status to determine road surface and driving conditions. The CX7’
s onboard computer then automatically determines which of three different modes of
front/rear torque distribution should be engaged: Normal, Sport, or Snow (for slippery
surfaces). The active torque coupling mounted in front of the rear differential is
electronically controlled in accordance with the data provided by the computer, adjusting
front/rear wheel torque distribution between 100:0 and 50:50 to deliver optimum drive
power to each axle. The result is that the most power and traction are made available under
all conditions; positive acceleration and confident handling are provided regardless of
constantly changing road conditions, as well as the ability to fully balance the vehicle in a
turn by skilful use of the accelerator pedal.
Unlike many competitor offerings, the torque transfer system in the CX-7 seamlessly
integrates the inherent stability of all-wheel drive; because the active torque coupling is
controlled electronically, it can react to wheel slippage much more rapidly than conventional
gear- or fluid-controlled systems. To ensure consistent power delivery under all weather and
driving conditions, the Power Take-Off (PTO) system on the centre differential that
distributes torque to the rear axle is fitted with its own liquid-cooled cooling system. "
Once the computer has shifted into snow or sport mode it pre-loads the rear axle so you don't have to wait for slippage. As oppossed to the system in the 01-04 Tribute where the wheels had to actually slip before the AWD kicked in.
For those debating the TCS system here is the blurb from the manual on that:
"The braking system works in synergy with the CX-7’s Dynamic Stability Control (DSC),
incorporating a traction control system (TCS), to exhibit an outstanding level of active
safety. The Dynamic Stability Control system is designed to activate when the vehicle is
taking a turn too quickly for the road conditions. DSC compares the driver's intended
direction (from the steering wheel angle) to the actual vehicle path; if the system senses
understeer or oversteer, it applies braking force, and reduces engine torque if required, to
correct the situation.
Traction control systems generally come in one of two primary systems: an ABS-based
system, or an engine management system. Both systems use the ABS wheel speed sensors
to determine if there is wheel spin (wheel speed greater than vehicle speed). The CX-7
system uses engine management to reduce the amount of power output by reducing fuel,
ignition timing and throttle position to reduce wheel spin. This system is superior to systems
that use the ABS brakes to slow down the spinning wheel – ABS systems have a tendency
to be very jarring in their operation and can overheat the brakes if used for extended
periods of time.
The CX-7’s traction control system (TCS) deals with the problem of the
engine supplying too much power for road conditions right at the source; when wheel spin is
detected, the TCS simply reduces the engine’s power output until the wheel spin stops.
I hope, sincerely, the above paragraph isn't true, otherwise CX-7 owers are likely to spend a lot of time with TCS disabled. If only one wheel is "stuck", freely "spinning", the only solution is to apply braking to that one wheel ("virtual" LSD functionality) in order to sustain a high level of engine torque to drive the vehicle via the wheels remaining with traction. And yes, the engine MUST also be dethrottled simultaneously.
I would be VERY surprised if the above is the entire TCS "story".
Modern day vehicles almost all make use of TCS to provide some level of LSD, "virtual" LSD to be sure, but just the same....
The way TCS on the F/awd CX-7 SHOULD work.
If wheelspin/slip is detected and the awd system is NOT fully engaged then TCS should command full awd engagement FIRST. If wheelspin/slip still persists the question becomes, one front wheel or both?
With only one front wheel having lost traction the obvious solution is to apply braking, moderately so, to only the slipping wheel ("virtual" LSD functionality) in order to maintain engine torque to a high level. Also obvious, the engine MUST be simultaneously dethrottled in order to help alleviate the high potential for loss of directional control resulting from loss of traction at the front.
In many commonplace wintertime conditions the immediate result of this virtual LSD activity, moderate braking of the slipping wheel, will be slipping of the "opposite" wheel in addition.
Should both front wheels lose traction simultaneously the potential for loss of directional becomes quite dire and therefore recovery from this circumstance must be as instant as the manufacturer can provide. Therefore I cannot see a circumstance wherein both front brakes wouldn't be applied while simultaneously dethrottling the engine.
But there remains at least one circumstance wherein Mazda3's explanation of TCS might prevail. Suppose the awd system is fully engaged, or even partially so, and it is both rear wheels that have developed wheelspin/slip due to too much engine torque being used for roadbed conditions. There is some danger, potentially, in the initial use of brakes in this instance. Braking both rear wheels in this instance might very well result in the rear wheelspin/slip quickly "leap-frogging" to the front wheels and that might very well prove disastrous. So it would be very prudent design to dethrottle the engine first and then later, within a few hundred milliseconds, apply braking to the rear wheels should the dethrottling not alleviate the rear wheelspin.
In that case it is perfectly acceptable to first/initially simply dethrottle the engine in an effort to regain traction since loss of directional control in this instance is not directly threatened. On the other hand if rear wheelspin/slip persists and the driver doesn't quickly respond by "feathering" the throttle then within a few hundred milliseconds the brake will be used in addition.
Obviously, again, should it be only one rear wheel slipping then the virtual LSD aspects of TCS will automatically brake the slipping wheel and possibly dethrottle the engine if braking turns out not to be an aid alone or if braking one rear wheel simply results in its opposite number also losing traction.
Hope this helps.
Oh, one more thing.
On some vehicles in certain circumstances TCS will be pre-emptive in dethrottling the engine. Enter a tight turn at low speed while attempting to rapidly accelerate and it is highly likely that TCS will SEVERELY dethrottle the engine almost instantly. It is important note that in this circumstance the awd system CANNOT(***) be fully engaged, perhaps not even partially, due to the potential for driveline windup.
And try a quick/fast launch with the FWD version and with the turbo spooled up and TCS will very likely instantly intervene.
*** It is probable that the awd system will be DISENGAGED automatically when the brakes are applied, when turning tightly, and/or if DSC is active.
A good detailed description of these new F/awd systems can be had at techinfo.toyota.com as they are now used in the new Venza and the 2010 RX350.
