Auxiliary Lighting Defined
bbrich57
2004 Mazda3 HB
I decided to begin this thread as from the many posts I've read there seems to be a lot of confusion surrounding auxiliary lighting, what it's proper uses are and how to mount and wire them.
I used to club race (street rally and autoX) two different cars back in the '80's, and got very interested in auxiliary lights. I had done a lot of research and managed to install a few sets as well.
My Volvo sedan ended up with three sets of additional lights, two sets of fogs (yellow and white,) and a set of passing lights, all relayed, switched, wired and mounted correctly for their intended use, and (questionably) legal. Though both were SAE approved two sets of fogs were questionable, and my H4 E spec headlights were certainly not legal in the US ('had the change them for inspection,) but I managed to get throught Pa. State inspection for several years w/o incident.
I hope you all can benefit from my past experiences.
Please feel free to add any updates, ask questions or make any comments you wish.
Fog/Cornering lights: These are the lights most often mounted from the factory. Usually mounted low for best results and connected to the low beams only. Deeply fluted lens, and/or reflector for a wide flat (and short) beam. Often yellow in color to help the driver distinguish the differences in objects better, and to help eliminate the glare and reflection associated w/foggy conditions. Fog lights always have a bulb diffuser to reflect the complete light output back into the reflector.
When used as a cornering lamp, they may be clear/white in color and/or mounted up higher.
e.g. I used a set of white fogs, mounted on top of the bumper, as cornering lights, and a set of yellow fogs underneath for poor conditions when I used to run street rally's w/my Volvo sedan.
Driving lights: Mounted @ the same level and as close to the high beams whenever space allows. Used in conjunction with the high beams, they're nearly always clear/white in color (some pro-racing series use yellow DL's to distiguish different classes running in the same race at the same time,) w/a lightly, or multi-fluted lens or reflector. These will throw a long beam that is more focused (narrower) than std high beams, but more diffused than pencil/spot beams.
Combination beams: When mounting space is limited. W/dual lenses and often (but not always) dual bulbs these carry both a fog lens for a wide pattern and a driving lens for a more direct, focused pattern. The fog portion of the lens may be yellow or white. Mounting should be between low and high (usually just below the bumper) as these lights are a hybrid/compromise, and in my opinion should be avoided, especially if sharing a bulb for both functions.
Passing lights: These throw a narrower, longer beam than driving lights, but not as narrow as a pencil/spot beam. Their lenses (or reflectors) are "pixeled" and are always clear/white. They almost always carry a bulb diffuser to reflect light output back into the reflector. These should be mounted and connected as driving lights would be, high beams only.
e.g. I had a set on two different cars I owned and LOVED them, but they are hard to find in this country. From my experience, they fill in that "hole" caused by std high beams that reflect light from the sides but "seem" to dissappear on blacktop. The effect of passing lights from the drivers seat is one of a completely lighted oval pattern. As I'd said, I loved mine a lot.
Passing Light Lens complete w/stone chips. Note the vertical fluting and horizontal pixeling.​
Pencil/spot beam: Always a clear/white lens, non-fluted or pixeled, and mounted wherever additional light is needed, but usually as high as possible. These light don't often have a bulb diffuser as light is directed straight out as well as allowed to reflect back naturally. These throw a very long, narrow, glaring pattern, as the name implies, and should only be used w/high beam headlights, or as utility/off-road lights. They are usually not legal and are to be kept off and covered when driving on public roads.
Also, remember that any light will make the most of it's available output if mounted in a round (parabolic) reflector/round lens, and in this case bigger is better. That's one reason I am not a fan of the new '07 Mazda fogs or the rectangualr headlights so popular in the '80's/'90's.
I hope this helps you decide your accessory lighting needs, how and where to mount them and how to use them.
Remember, it is your duty to use them responsibly on public roads and where other traffic exists.
LIGHT AIMING GUIDE
Proper auxiliary lamp aiming is the most important part of an installation. If the lamps are not properly aimed they will not achieve optimum performance and they can be very dangerous. The danger comes from the beam pattern being aimed right into oncoming vehicles thus blinding the driver. Check the Lamp Selection Guide on page 4 for the definitions of different types of lights and their intended use.
FOG/FOUL WEATHER LIGHTS
Traditional fog lights are usually mounted under the front bumper about 10-24 inches from the ground. There are two important issues to address when installing fog lights, the first is to minimize the amount of return glare into the driver's eyes, and the other is to minimize glare into oncoming driver's eyes. Both must be accomplished while putting as much light as possible on the road. These fog/foul weather light aiming instructions are suggestions taken from common practice and the S.A.E. standard J583. Some modifications to these instructions may be necessary to minimize glare.
Visual aim is made with the top of the beam 4 inches below the lamp center at 25 feet with the lamp facing straight forward. (See below.)
DRIVING LIGHTS
Typically, driving lights are mounted above the front bumper about 14-30 inches from the ground to provide extra high beam illumination. Driving lights can be mounted below the bumper, although they will not be as effective because the light will hit the ground sooner and reduce the range of the light. Visual aim is made with the center of the beam hot spot 1.5 inches below the lamp center at 25 feet with the lamp facing straight forward. (See below.)
I just took the PIAA Dealer Lamp course and I thought I would add this.
Jeebus! I get it! I was wrong!
(lol2)
(lol2)
Don't worry Chris. It wasn't only reading your post that caused me to rewrite and extend mine into this thread. I've seen many others that are/were justas confused... just as I was when I started looking into it way back in the '80's.
