with the o/d button, i just ripped it out from the stock one and bought an on/off relay switch from radio shack and rewired it to that and hid the button by my seat belt clip... no one can see it.
as for the momo knob, the auto has a silver button on the top that u press down. u cant see it until u see it in person.
WARNING
this knob was a b**** to install, i wont s*** you guys.
the knob base is too thin for the metal rod shifter. u need to shave the metal rod so it is thin enough to fit the momo shifter. i used a hack saw at first (took me 3+ hours) to cut it to fit, the later, i cut off another inch or so of the metal rod and shaved it once more with a dremel. saves soooooo much time! but watch out, the metal shaft can get SUPER HOT... haha yah, i kinda burned myself by accident, oh well
but yah, thats about it. pm me with any more qs!
my old pms:
____________________________
Shifter
okay well heres the run down:
its hard unless u have the right tools
once u remove the stock shifter, there will be a metal poll this thick:
O
you need to find a way to fit the shifter on which is this thick:
O
okay, hope u know what i mean haha. the momo shifter wont fit on the metal shifter of the car because it is too thick. u have to cut down the diameter of the metal shifter... i got a saw and made a sqaure so the momo shifter fit over it. boy was it a b****. vic said u need a di-grinder? idk what that is, but im sure itll help. gl dude. btw, sanding the metal poll wont help, itll take FOREVER, i tried it
gl and pm me with anymore questions
peace
chris
_____________________________
hey, just pull out the rod and cut the top off
also i sent this to subghetto::
"hey, yup, its a 2002 auto with o/d.
well one, u need a momo auto shifter and momo boot or like pirana did, get a boot from mazda for a 5spd protege.
second, u need to get a button to replace the OD button on the stock shifter, just go to radio shack and rewire the new button, not too hard. then u gotta look for a new place for it, i just drilled a hole in the center console, below the shifter, and put the button there.
third, when u remove the shifter, ull see the metal rod with a plastice piece in the center... this is where it gets really tricky. the metal rod's diameter is too wide for the momo shifter, so u need to find a way to sand the rod down and make the circumfrence smaller... what i did was...
got a hack saw, and cut the circular rod into a square so that it was small enough to fit the momo knob on. if im mot mistaken, pirana said u need a die-grinder? idk what that is. u can try sanding the metal rod, but ull take FOREVER, i tried it, even with an electrical sander.
after u get the knob on, everything should be self explanitory
well gl dude... any more questions, just pm me, ill try to help.
peace
chris"
gl dude - chris
__________________________________________
thats about as detailed as i can get
peace!
