I need some advice... I have a 2003 MP5 with only 19k miles.. Well for some reason if I downshift into 1st at too high of an RPM the tranny will lag severly bad and wont allow me to shift into 2nd gear, this has happend to me many of times, it's usualy when im going around a corner or slowing down for a dip..
Well the main problem is last week it wouldn't let me shift into 2nd and I didn't notice it cause my radio was full blast and it put my tac all the way into the redline (7500rpm!!!) until my car basicly was losing power from over reving then it finaly shifted into 2nd gear.. now my engine sounds like I have bent valves or something... it sounds like s*** like the lifters are sticking.. has a loud idle with a slight sticky lifter sound.. Basicly I'm guessing it ****** up my engine bad..
Is this covered under my warrenty? What do I tell the dealer I take it to? Is this a commen issue for the AT trannys to lag when you downshift to 1st from 2nd, then back into 2nd?
Anyway let me know, thanks guys.
