I have never cracked 25 mpg in the MS3 with mixed driving, and I have tried hard...shifting at 2000K for an entire tank on synthetic oil and driving it incredibly soft, using cruise control, no AC, etc. I still get under 25 mpg. I don't know where you guys live, but there must be a difference in the air or the terrain. In Georgia I really doubt anyone is doing any better than me without an intake.
shifting at 2krpms is not necessarily the best thing for gas mileage. it basically means that you may end up pushing down harder on the throttle than you should have to in order to get acceleration. as happy and angry says, it means that you're actually trying to push the car outside of its power band, and that's not the efficient way to use your fuel.
here's some info for a more technical explanation:
at <2krpms, if you press down moderately hard on the throttle, you will see the MAP go from -20vac to 0psi very easily. doing the same thing at >3krpms, you might hit like -10vac.
what does this mean? well, if you get a Dash Hawk, you will see that our cars run at an AFR of about 14.x most of the time (unless you're not pressing down on the throttle or you're boosting). AFR = air/fuel ratio, so if your air/fuel ratio is staying about the same, but your MAP just shot way up, your ECU will fire up the fuel injector pressure in order to squirt way more gas into the engine cylinders to maintain its commanded AFR. when you're outside of your power band, it can cost you more fuel to get the same amount of acceleration out of your engine as compared to being in a lower gear but staying within your power band. the lower gear may be running at higher RPMS (more total detonations), but because it's running at a significantly lower MAP, which means significantly less fuel is injected into the cylinder per detonation, the total fuel burned may actually be less under the same acceleration conditions.
the above conditions are why i asked yashart if he was driving slightly uphill for extended periods of time, because that is a perfect example of a cruise condition where being in a higher gear may actually hurt you, since you will have to apply more throttle pressure to maintain your speed than if you were in a lower gear.
anyways...this is just another angle for you to try. give it a shot sometime and see if it helps you, because your current method seems not to be working as well as it could...=/ this, btw, is why i think boost gauges help...because you can see exactly how far into the vac you are.
