Anyone with Indiglo gauges...
Gizmo360
Laser Blue Mica MP3
...Specifically, the Reverse Indiglos from Corksport.com...I was just wondering if the were easy to install or what? Do they just slip over the needles, and if so, they don't get stuck do they? Also, the needles still stay amber-colored right? How about the odometer, wouldn't it look kinda funny still amber? Thanks in advance guys...
someone has them on here. be very careful removing the needles i think they broke a few.
Speedo and Tach go on ok, it is the Fuel/temp gauges that you have to be very careful of. IF you tweak them ever so slightly (pop) then you are SOL. I currently do not have a working temp gauge, I just glued the needle back on so it always reads in the middle. I like the look though. They also had to be trimmed a little to fit correctly. Alot more work, and $$ if you screw up, then they are worth, but if you need a different color, go for it
Nah, I don't really need them or nothing, I was just wondering for if I ever decide to. I actually kinda like the amber colored gauges. Thanks guys!
Nope, been tried way back by somebody. There are amber colored boots on the lights that somebody tried replacing with blue, but the translucent parts of the guages have a tint to them as well.
Chris
I have them:
Be VERY careful with the needles. It seems like everyone's breaking them all of a sudden. Don't put any pressure on them or they will snap.
I'll have a pic of them tomorrow when I wire them. I installed the faces. I had to cut the gauges though. The fuel and temp need to be cut all the way from the needle hole to the right edge and they can go on no sweat. The other 2 were a b**** because I didn't want to cut them too much, but ended up having to go back and cut them more and more till it fit. It's better to screw up with a $25 set of gauges than a $250 gauge cluster. So, BE CAREFUL WITH THE NEEDLES!!!!
