Everything I've read on this site and elsewhere says an alternator should almost outlast the car - 100,000 - 180,000 MILES.
My CX-5 is the KE version (the earlier models) but with a 2.5 L imported from Japan - it is 2014 but has only 51,000 KM (not miles - so around 30,000 miles)
Mazda dealer says the alternator is failing - with 11 something showing on the multimeter. But I'm not convinced. Couldn't it be the belts? Or the belt tightener? Also, the 2.5 L I have (gas) is not a turbo, but the belt they installed (PY0115909A) is for a turbo as far as I can tell and is slightly longer (by half a cm) - could that cause the lower output - not tight enough? I just changed the battery too.
