anyone know what this sound is?
victor, remember when we modified that INJEN prototype? well i checked the hole that was welded shut and i actually see a very tiny opening in it. you think it matters?
if u blow into the intake pipe, closing the other side, will the air come out of that hole?
if it's like a pin hole, i wouldnt worry about it.....not much air can pass through that anyway.
1FASTMSP said:
you want to elaborate on what exactly is a "sueeling sound"?(scratch)
I believe a sueeling sound is a squeeling sound. I think he means the turbo.
Dude with the sueel: Your turbo spins up as rpm rises and when it is spinning very fast a squeeling sound is normal. If it sounds like metal scraping on metal, or if it is uneven or "scratchy" then your turbo could be going bad, but a "whine" at higher rpm is normal.
