Anybody have gaps on their bumpers?
steven88
Mazdaspeed 3 Sport
was wondering if anybody has a similar experience? It's only on the passenger side....I pulled my bumper for HID install...and when I re assembled everything I came up with this...I said no problem, pulled everything off again and made sure everything lines up and securely fit...still to no avail
Is this a common problem with Mazda 3's? Does anyone have a fix for it? Any input on this subject would be greatly appreciated!
My front seems to be fine but the rear starts off fine (nice and even) and ends with a larger gap between quarter panel and bumper. I have looked at many 3's and no two are alike. The uniformity of the gap varies car to car. On my Mazdaspeed MX5 it was a royal pain to realign the bumper. There is not very much to hold it on or adjust. Seems to be the same case with the 3's.
Mine's perfect but my wife's brand new Civic Si has a weird gap problem on the right side. Does this just happen sometimes?
I find I have to thump the passenger side bumper end back in place every so often. Haven't figured what makes it go out of alignment. I suspect it's when I park and the chin spoiler contacts the curb, usually just a "brush".
Correct! I have seen this happen on a regular 3 right in front of me. It does not take much contact to pop the edges of the bumper cover out of place.
someone on another forum suggested to me that I loosen my headlight bolts and lift UP on the headlight as far as it can go...then tighten the bolts down....it worked out for him so I will be giving it a shot....I hope this really fixes the problem because this all started after my HID install (removing headlights)
Mine looked like that recently since I let a friend drive the car, whereby he put it in 1st instead of R on a diagonal park. This resulted in him driving up onto the curb, then backing off, which pulled the bumper away and broke one of the clips where wheel liner meets bumper.
Check your clips?
Check your clips?
Yup everything is in tact...I guess it's just a common problem with mazda 3 bumpers
there is 3 metal clips that need to sandwich between bumper and fender. If any of those clips are broken you will get that gap. I hit part of a driveway and my bumper came out the left side. After fixing most of it it looks like 1 tab/metal part broke off the little bracket behind the bumper and now I get theat gap. So I called Mazda and they can order the part in 2 days...I think its like 25 bucks
I had that problem too after my first attempt at my HID install. I had to go back in there to fix a small problem and the second time around it was gone ...
Must have missed something
