Any tips for removing and replacing miata door belt-line molding?
aMaff
High Speed Low Drag
1992 Miata / 2003 Pathfinder
The rubber on the door belt-line moldings is totally toast. It instead has been replaced by rusty metal which becomes scalding hot when the sun's out (don't even think of resting your arm on the door if the car's been sitting for more than a couple minutes). Anyway, the reason I posted this thread is because in the shop manual the note in regards to removing the molding is "Step 1: Remove door mirror, Step 2: remove front belt line molding". I tried just pulling on the thing and prying on it some, but it seems that there may just be a tick more to the equation than that. Any suggestions? I've got the new ones sitting here also, so any installation notes would also be greatly appreciated.
TIA
Andrew
I'd look at the new molding to see how it mounts..
