Another seized front brake caliper pin
norcalP5
2003 P5
In the middle of a brake job. LF caliper upper pin seized into caliper. Any Ideas how to free it so I can clean and lubed them up? I tried to lift them up at first. The pin is seized and when I lifted calipers up the pin rotates with the caliper. I have left them soaking in PB blaster. I gave it a few good "taps" using 2x4 and a mallet. It budged only a tiny bit. Any recommendations on how to free the caliper from the rusty grip
You can try heating the pin, that's worked for me in the past.
It has also led to the pin snapping...
Rotate it all the way up and use the 2x4 and a hammer to beat it off of the pin. Tie the caliper up so when it falls it's not supported by the hose.
