whats the reasoning behind trying to run such a big tire?I see alot of people running aggressive wheel fitment. I wanted to know if anyone has tried to fit 245/40/17 on their protege. I wanted to run the that tire size with a set of 17x8 +40 wheels. Any thoughts? I know I will need some major fender rolling.
THread jack, i am looking at buying Subaru sti rims. they are 17x8 rims, will they fit on my protege es
im running toikos hp blues.
I want to track the car often and I know having a proper tire is probably one of the best upgrades.
machining: machine hub bore out to fit protege
spacer: 5mm to clear strut
you might need a roll, but yea that should be ok
edit: yea i would go with the 205 45 tire as well, the 215 might cause some rubbing issues.
yes i do know who, lol just wasnt sure if u were goin to slam or go for the function
Front: 17x9 +35
Rear: 17x9 +15, -7 degrees camber
this is funkalicious
Did he do custom work on his quarter panel to get that 17x 9 +15 to fit so well ..his camber dont even look -7.. n mine is hella poking
