Look at these beasts: http://www.stancenation.com/2011/02/22/coming-soon-mazda-invasion/
That's my old setup to a tee. I never hit a rim. Lot's of tire rubbing tho. I ran 225/45 in front, no issues. 215/45 in the back rubbed if I was driving hard, tho. That's with Illuminas set at full dampening and a decent linear spring (RS*Racing). 17x8 +35 is about as aggressive as you can go on the BJ platform without coilovers, honestly. Or at least sleeves.
Think I can reduce most of the rubbing with more camber than you? You only had -1 I believe and a fender pull. Although your tires look beefier than zachs evo9s(same set up).
I'm looking at some 17x8 +53. I need the hub bored and a 5mm spacer/extended lugs just to clear the strut orr a 15mm bolt on spacer with hub size if the stock studs fit in the rims. Tough.
with extended studs i would do 5 or 10mm to fit. only problem is i would have to always run the spacer. even with my snows. and up here in the artic it is not the best idea.
With extended studs you could run an open ended lug nut without the spacer..
Open end lugs are bad unless you're in cali. Just my .02 Not worth all the grime and salty crap that can build up in there. Might as well just get closed lugs designed for use with extended studs. They are common. I have a couple sets, well actually only 1 set now. Just sold the Traklites....![]()
^ i'm pretty sure flyinhawaiian has those wheels on his MSP. might ask him what tires he's running...
Finally got my new tires on this morning and after 8mm spacers all around and extended studs plus the mz6 front rotor difference.
Kumho Ecsta XS 225/40-18 (very square profile huge footprint) on 18x8 +40 rear and +37 front still slammed rubbing only when I accellerate, slow down, or turn LOL!
Soon to be remedied with some zipties on the front fender liner and maybe a little more camber and some more rolled up newpaper all around one more time. Also got on it a bit in 3rd where I can usually light them up easily and they didn't even break traction
Pics later
Hells yea man you're car is a beast, black with red trim would be perfect. Glad to hear the kuhmos are working out for you. I want to eventually put dunlop star specs on my 8" wide enkeis for the trackI'll get some pics tomorrow still another round to go on my fenders in the morning. But these freaking tires stick like glue...car is a rocket with them!
Wheels are just rotas and they are flaking all around the lugs. May end up blasting them and doing black with red stripe??
