Striker187
- 2008 MS3 GT
amen to that jred. being careful never hurt anybody.
jred321 said:im not trusting them for daily driving at 15psi, at the track for a run or 2 or a dyno pull or so then yea, it's fine, but daily driving i don't want my injectors at more than 100% duty cycle. the stock injectors are really small for a turbo car. if you compute the duty cycle, they're almost maxed out already on stock boost. i'm not trusting them over 10psi, but i'd rather not blow up my motor so i err on the side of caution
Striker187 said:doggman - you'll more than likely want a pro to tune the emanage fuel map for you. you use a laptop to program it. but i think with spool's program, it will come fully programmed so no tuning necessary, though adjustments may need to be made depending on your mods.
without the vacuum line connected, your bpv won't open. the bpv stays closed by either the use of a spring or in hks's design, the boost pressure helps to hold the valve closed. but to open it, the bpv needs the vacuum pressure to pull the valve open (i.e. when you let off the throttle). so essentially, i think you'll be running without a bpv.
technically they aren't performing their job anymore beyond that, they're totally open and how much fuel going in is based on fuel pressure and isn't dependent on the injector anymore. while this is better for the atomization of the fuel, i'm not going to trust it every day. and i don't know if it is actually 10psi, that was just an estimate, im just saying higher boost. tuning is the key to making power, learn how to do that first before just throwing mods at things and hoping they don't blow up.doggman said:so jred321 your tellin me that if i run 10 psi te injectors wont be able to handle it? man this sux. hopefullyi can run 10psibefore i have to get new injectors.
are you sure it was the vacuum line and not the return tube?doggman said:but i have driven it and the bpv deffinitly opens. it seems like it is louder. i dont kno why but it seems as if the bpv has gotten louder. also will the check engine light come on?
true, but i don't want to push limits without being able to monitor them properly so i don't go blowing anything up or not knowing exactly why something failed, and i don't have a wideband or data logger among other things to really know whats going on in there.Ryan said:but hey... being careful never hurt anyone but without the guys willing to take a risk u'd never know the full potential.![]()
jred321 said:true, but i don't want to push limits without being able to monitor them properly so i don't go blowing anything up or not knowing exactly why something failed, and i don't have a wideband among other things to really know whats going on in there.
you could add extra injectors, pruven uses 8 550's on the evo they submitted for the uscc, just plumbing/controlling them can be a painRyan said:would there be an advantage of adding more of the same injectors we have more openings.. would that work.. to releave it some..?
i would suggest a wideband and something like this http://pocketlogger.com/?page=prod&prod=obd2 to monitor as you push limits so if something fails you can see what it was and you'll know how to correct it, or you can hopefully see it just before it does fail so you can save yourself some money and not break itRyan said:yeah yoru going the safer route and thats fine thats what i was gonna do till i got zealous so i guess i'll be one of the first to find out just how far we can push this... after my rebuild it wont be the same.. but i shoudl be able to monitor things alot better...
jred321 said:are you sure it was the vacuum line and not the return tube?
turning up the boost is not tuning, it's turning up the boost. if you turn it up to 10psi, you'll probably be fine in stock tune. beyond that you are going to need to control fuel/timing in some way. options are very limited right now. if you want to do things right, start by reading corky bell's book and leaving everything stock, then get some monitoring tools, then you can assess weaknesses in the system and fix them.doggman said:ya because you can feel the suction from the line. ok you do bring up a real good point. you dont just want to through things on and hope the engne doesnt blow up, how would you go about adding mods but tuning them as you go. see what i dont understand is how do you tune the car when you crank up the boost to like 10 psi. isnt that tuning in itself? how else would you raise the boost. if i got the b.c and the b.g and turned the boost to 10 psi how else could i tune it. do you get what i mean. what else could i do. i want to run more boost but of course i want to do it safely. see what i really want to do is get the emanage fuel management system and then get the rfl bov. i also want to get a b.g and a b.c so that i can turn up the psi. but i also want to do safely. so what should i go about doning then so that i tun as i go and do tings right not quick.
from a few posts up. boost gauge is necessary, oil temp/pressure, water temp/pressure would also be nice to know as well. and please read corky's book before doing anything that may blow up your cari would suggest a wideband and something like this http://pocketlogger.com/?page=prod&prod=obd2 to monitor as you push limits so if something fails you can see what it was and you'll know how to correct it, or you can hopefully see it just before it does fail so you can save yourself some money and not break it
