I cant figure out how to zip files to upload it for you guys...but when I compare every setting between the one I have stock on my AFC and the SuperStock map they are identical...unless there is something Im missing....
Here's a breakdown of my settings:
Under Options:
-System Settings:
--Vacuum/pressure....Program signal calibrator
-Engine Settings:
--4 cylinder.....4 stroke
-Output Settings:
--PWM Mode: Pressure 0 to 30psi/3 vdc fs
--Output A Mode: Aux fuel pump with abortive start time
--Output B Mode: Over RPM and Pressure (this was originally over pressure, read on the how-to elsewhere on this site that either was OK)
--Output C mode: Inj A and B over /latched
--Over RPM: 6000
--Over Pressure: -1 (originally set to 1.1, changed per what I read elsewhere)
--Over INJ: 90%
--Fuel pump start pressure psi: -1
--Fuel pump run time: 3
--Fuel pump start up time: 120
-Aux Input Settings:
--Aux input A: Coefficient a - 9, coefficient b - 1.4 (used calculator to obtain these values...using NGK Powerdex Wideband O2, 0-5V auxillary output)
Fuel Maps A & B - identical to SuperMapStock
Under Options:
-System Settings:
-Engine Settings:
-Output Settings:
--Over RPM: 6000
--Over INJ: 90%
