Ok, so I finally got around to installing the SS AFC and I am having problems.  I have a feeling the stock map that came on the unit was completely wrong.  Before I explain, I bought this unit brand new from ProtegeGarage so I know its not used and previously tampered with.
So the map that was loaded on the unit was all over the place with its values.  Map A (fuel) was almost completely 10's until around 2.2v to 2.8v and the values varied between 0-20,  with the values changing between 500-4000rpm.
Map B (Timing) also had some very strange values starting at 2.2v as well.  As the voltage increased the values increased as well going up to 20 at the highest point.  On a side note, I downloaded the SuperMapStock and realized that there were all 0's in the Map B.
This seemed very strange to me and my car would start but as soon as I would get into boost it would get serious hesitation.  Should I try the SuperMapStock and see what happens or is there a way to download the correct normal stock map that is loaded on the unit, we already had to change values in order to get the car to drive.
Mods that I have:
Custom FMIC and hardpipes
Forge BOV
Custom 3" turboback
Colder Plugs
Replaced actuator (Runs at about 7.5-8psi)
Thanks for any help, at least my car is driving but I really want this to work.  BTW, we are using a wideband (Zeitronix) to read our A/F and boost values.
Mike
