AFC-SplitSecond PSC1 Map Library
you can't just buy a afc from split second. I talked to the guys from split second and they explained that protegegarage's afc's from tailor made from our cars. you are ask them to make one for your msp buy it would be about 400$ no where near the 239$ you were probaly looking at.
well i did that, but i mean what do i have to do on the computer or something? i am using windows 7 btw. the software seems to have loaded on the pc just fine...
you should really go to the website and read the U-tune PDF, it explains everything in detail.
But what you do is connect to the ecu, car on engine off, once connected go to fuel map, then write to ECU, or read from ECU, whatever your trying to do
so is the stock map good for up to 10psi is what i read? or the "super map"?
also i am reading that pdf. where it says to connect to the ftc on the right and it gives me like 8 ports what do i do?
try each com port until you find one that works, each port on your computer has a different COM #
and the superstock map is actually good up to 13-14psi, thts what I was running when I had the stock turbo
I wouldn't say this is recommended, unless a new lower end build is in your future plans and budget.
