AEM FIC maps
DrumKidd
2003.5 Mazdaspeed Protege #2043 Silver
Morning all!
I'm wondering if anyone has any AEM FIC maps. Currently I'm running with a stock turbo and psi, Injen cia, hard pipes, stock inter-cooler, stock injectors, turbosmart dual bov, and Perrin 3" turbo back (cat-less).
Looking to see what you guys have, if any.
Thanks!
I would be able to, but there is no map loaded on the computer. I bought it off jdwk, but he's away this weekend and I forgot about it. So, I can't open the FIC to tune, because you need to open a map in order to do so. So I'm currently at a stand still.
Ahhh that sucks man, I know that when I got a map off of someone else for my afc it was like going backwards. The map was so terrible for my car I had to start from scratch
Well, I know I'm going to have to make some edits, and I'm fine with that. Either way though, I need something to open it.
If you open the FIC software with the FIC connected to your computer and the ignition set to the on position, you should be able to hit the "connect to FIC" button. Though if you need a map, there should be a base calibration file that comes with the FIC software. Try checking your folder in "All Programs".
He ended up getting my message. I'm set with a map now, thank you!
Now comes the fun part... haha! Hopefully, I have some friends who aren't busy this week!
Hey man, I am here to help you. Every car is going to be different because of that wonderful high voltage MAF we have, but my tune will get you as close as you can get to perfection.
You can give me a call whenever you feel like it. I'll get you running again.
