AccessPORT & AccessTUNER Updates for MS3 and MS6
Summary
Several enhancements have been implemented on the MAZDASPEED3 & MAZDASPEED6 AccessPORT platform.
  • Launch Control and Flat Foot Shifting have been implemented in AccessTUNER Race and AccessTUNER Pro
  • MAZDASPEED3 maps up-reved to v1.04
  • MAZDASPEED6 maps up-reved to v1.01
  • DTC P0421 Catalyst Efficiency has been disabled
  • Several software bugs have been addressed
  • New firmware has been released
Please note that in order to take advantage of all of these enhancements, AP Manager must be updated to 1.2.1.0, the AccessPORT firmware must be updated to 1.4.0.0, maps must be updated to MS3 v1.04 and MS6 v1.01 and AccessTUNER Race must be updated to 1.7.3.0. Additional details and instructions regarding these updates are shown below:
AP Manager 1.2.1.0
AP Manager must be updated to version 1.2.1.0. Download AP Manager 1.2.1.0 here.
AccessPORT Firmware 1.4.0.0
Firmware must be updated to latest revision to take advantage of all enhancements. Firmware 1.4.0.0 includes the following enhancements:
  • Federal and California models now treated as one model
  • DTC P0421 defeated in all Stage 2 and Stage 2+ maps
  • Expanded MS6 maps database
For Firmware Update instructions, please visit the Mazda AccessPORT Firmware Page and follow the Step-By-Step Instructions.​
AccessPORT Maps Up-Reved
Maps for the MAZDASPEED3 and MAZDASPEED6 have been Up-Reved. They are available for download in the MAZDASPEED AccessPORT Map Database.
Please note that in order for these maps to function properly, the AccessPORT Firmware must be updated to 1.4.0.0.
MAZDASPEED3 v1.04 Maps
Stage1: Adjustments made for more consistent boost control. Map saved as new format that is compatible with new LC/FFS features
Stage2: Adjustments made for more consistent boost control and defeated MIL (see below). Map saved as new format that is compatible with new LC/FFS features​
MAZDASPEED6 v1.04 Maps
Stage1: Adjustments made for more consistent boost control, boost, fueling, and ignition changes for additional power improvements. Map saved as new format that is compatible with new LC/FFS features
Stage2: Adjustments made for more consistent boost control, boost, fueling, ignition changes for additional power improvements, and defeated MIL code. Map saved as new format that is compatible with new LC/FFS features
Expanded Map Database
  • Stage1 93 Octane
  • Stage1+SF 93 Octane
  • Stage2 93 Octane
  • Stage2+SF 93 Octane
AccessTUNER 1.7.3.0
Several important enhancements have been made to AccessTUNER software for the MAZDASPEED3 and MAZDASPEED6.
  • Launch Control and Flat Foot Shifting are supported and allow the end user to configure LC RPM and and FFS RPM in the map.
  • Updated Tuning Guides with Launch Control and Flat Foot Shifting sections are available for download on the MAZDASPEED3 and MAZDASPEED6 AccessTUNER product pages
  • DTC P0241 defeat is configurable
  • Bug fixes
    • Fixed camshaft phasing scalar
    • Fixed problem wit Boost Dynamic table not saving
    • Conversions fixed in following tables
      • Boost Comp - Baro
      • WG Duty - Baro Comp
      • WG Duty - Battery Comp
      • WG Duty - IAD Comp
    • Fixed ranges for Boost Table target values
Professional tuning facilities requiring the MAZDASPEED AccessTUNER Pro updates should contact Scott Brood at 801-713-0443 or wholesale@cobbtuning.com for download information.​
AccessTUNER Race users can download the updated software by visiting the MAZDASPEED3 AccesTUNER Race product page or MAZDASPEED6 AccessTUNER Race product page and click the DOWNLOAD button. Fill out the resulting survey, complete with vehicle Make/Model/Year information and the AccessPORT serial number. Please allow up to 24 hours for the notification that your software build is complete and ready for download.​
Happy Tuning!
Gary Sheehan
COBB Tuning
can not wait for this flash. i have to download the atr first right? its the beta one? because i dont have the 2gs for the other one
Thanks Cobb !!
Nice to see you guys still making improvments to the maps. I would like to know what more consistent boost control means exactly ?
Yes, AccessTUNER Race Beta is for end user tuning. AccessTUNER Pro is designed for professional tuning shops.
Gary Sheehan
COBB Tuning
I dont want to be a downer, but when I went to transfer my Stage 2 + SF Intake 91 it says map failed to download to AP (uhm)
Edit: I ran the AP updater before I tried to transfer the maps, does the updater update the firmware or do I have to download something separate? Thanks
The AccessPort updater will update the firmware to the latest version available. When you hook up your AP to your dongle, it will also update the dongle to a new version as well. Did this at lunch today. Are you using the accessport manager to transfer your maps ? The updater put some of the new maps on, but I had to download the 91 SF v104 from Cobbs site, and transfer it to my AP with the accessport manager.
I just downloaded the new AP manager and it seemed to transfer to the AP fine. Im gonna go hook it up to the car and see what happens. Thanks for your help man!
im thinking for launch control setting it at like 3200 rpms. or 3k. gunna have to test it out
I thought in one of our cars reviews Mazda said to launch at 2900rpms. I found it.
The Mazdaspeed 3 is only a bit less tricky to launch than a space shuttle. Most of the runs up the drag strip vanished in excessive tire smoke. Or they deflated when the driver, trying to stanch the wheelspin, inadvertently cued the waste gate. Or grabbed the wrong gear with the spongy shifter. Calls to Mazda yielded tips: Pop the clutch at 2900 rpm, upshift at 6000 — redline is 6700 — and flat-shift through second and third (which means don't lift at all — the mechanical equivalent of dropping a Steinway on the clutch and half-shafts and violating our test procedure).
"Don't worry," the engineers said, "it won't break."
http://www.caranddriver.com/reviews/car/06q4/2007_mazdaspeed_3-road_test
