I've become used to seeing basically no oil usage on our 2020, and my daughter's 2019, although I will always continue to check regularly. And I see almost nothing posted here from other owners about their CX-5 using oil, so IMO 1/2 quart in just under 2K miles is abnormal for these vehicles.
So for openers, I have to ask if you checked the level the same way both times, and particularly if you waited at least 5 minutes after shutting the engine off before checking. Next is the question of a possible slow leak, with the primary suspect being the filter or drain plug not being fully torqued.
In any case, I recommend checking the oil (and all other fluids as well) more frequently - a few hundred mile interval, or something like bi-weekly if you generally don't drive many miles. After doing this for a period of time, perhaps you will discover that your vehicle is actually not using/losing oil, and can then consider the observation that you posted to be an anomaly.
