- 2001 Pro 2.0 LX
it'll be interesting to see how much you can boost until spark becomes a major issue. you gonna contact nick for his new ignition system?
BlkZoomZoom said:I've done pretty much all the stuff you have done, with one big difference. I did almost all of it with my own two hands. Of course we won't know if that was a bad thing until it actually runs. lol
Oh I ended up putting a .040" shim under the pressure relief spring in the oil pump. Of course I don't have a permenant pressure gauge so I will have to hook up my tester one to see what pressures I get.
vindication said:it'll be interesting to see how much you can boost until spark becomes a major issue. you gonna contact nick for his new ignition system?
pdhaudio83 said:hopefully you dont lose as much coolant as i did when we tried to fire her up and noticed a leak![]()
BlkZoomZoom said:"I'm going to be controlling my VICS indepndently so I can determine when it kicks on or not.. I'm going to burn up some dyno runs determining when it is best to open it on my setup as well."
I have to get a pic to you. Your gonna love my new "VICS solenoid". I'll take a pic. tommorow.
<!-- / message --><!-- sig --> I doubt that it will push the pressure too far, but I won't know till I try.
TurfBurn said:Where did you leak?
I've tried to be REALLY meticulous about seals... My fuel lines have been checked a number of times.
BlkZoomZoom said:synthetic is a no no for break in.
pdhaudio83 said:are you going to throw synthetic in (wow, expensive) from the start? or break in on dino oil?
