The extra injectors are just before the throttle body on the right hand side of this picture. They are controlled by a stand alone system called a SDS-EIC-2. My domain page has some info on the system and a link. The entire setup is only $500.00 US and requires Positive Negative Tach Signal and manifold pressure to opperate. You might also want a A/F and a EGT to tune it because you set it. Once set, there are no further settings unless some fucktart moves the dials.MzD808SpD said:anyone here running a 5th injector setup on their MSP? and could you show pics and a how-to?
Thanks, It's UBER QUICK!!tekkie said:Brian that looks sweet man
Whats with the red warning label? I like it(thumb)Brian MP5T said:Here is the control Module...
It has a cloaking device now!!(thumb)tiwing said:Seen it first hand and have had a ride in Brian's. Frickin' AMAZING setup. I just want to know where he parks it, and when he's going to be away from home for a while. *drool*
It was in my last car that was for SPL...Jhova1012 said:Whats with the red warning label? I like it(thumb)
Around where I live it could be " FREE FATTY" as in free sex with one (hand)tekkie said:while we are on that topic of whats with, "free matty"????? I dont get it (dunno)
If your car is N/A and you add a turbo, The stock fuel system will not be able to add the sometimes double fuel requirement for the turbo. You will run lean and detonate.chamich said:what are the benefits of that 5th injector?
