$3500 MSP Performance Challenge
SP33D
Black Mica MSP
Idea stolen from 1stMP3 ;p
Your mission is to gain the most performance for $3500 or less. The car is a 2003 Mazdaspeed Protege with an Injen Cold Air Intake.. besides that, it's stock. You can use any prices so long as they can be found with a factory warrenty. Hence, only authorized vendors, no EBAY .
Install labor is not part of the $3500
The parts can include what ever you think will make for the best performance overall.
I think this will go along way to answer the, "Whats the best questions".
To recap:
1) The car is a 2003 Mazdaspeed Protege w/ Injen Cold Air Intake
2) The goal is to get the most performance out of an MSP
3) Any equipment can be used.
4) List equipment and prices
5) No Ebay, only authorized vendors that prices can be checked.
6) $3500 budget
Edit: It doesn't neccasairily have to be everything done at once for $3500... but maybe a couple top of the line things that you should start out with.
OK, have at it!
I don't understand... how do you win? How do you prove what's best? And why does it have a Injen CAI? Can it be taken off and sold? :p
Hacksaw - $20
pack of steel cutting blades $10
4 Spare "donuts" $50 each
Joe's MBC - $45 ( I think )
Take off the doors, trunk and hood. Put on the donuts, turn up the boost. Want more performance, start using that hacksaw - every pound counts.
Someone post the link I'm thinking of, I can't remember it.
*SPOOL FRONT MOUNT INTERCOOLER
$975.00 + Larger Intercooler Add $150.00
http://spool-turbo.com/Mazdaspeed.html
*SPOOL Mazdaspeed HARDPIPE
$400.00
http://spool-turbo.com/hardpipe.html
*Mazdaspeed CAT- BACK EXHAUST
$599.00
http://spool-turbo.com/turbobackexhaust.html
*Greddy e-01 boost controller
$539.00
http://spool-turbo.com/Electronics.html
*Apexi Twin chamber BOV
$185.00
http://spool-turbo.com/BlowOffValves.html
*B&M Short Shifter
$144.00
http://www.mazdaperformance.com
*JIC Magic FLTA2-RS
http://www.jic-magic.com/productsjic_susp_flta2rs.htm
lol i worked allday to tired to find the rest of the stuff i will continue later ;p
Okheres my crack at it:
Corksport Stainless Steel Brake lines: $100 www.corksport.com
Corksport/KVR Cross-Drilled Rotors: $300 www.corksport.com
JoeP MBC XZ: $45 www.joepmbc.com
JoeP Fuel Cut Defenser: $60 www.joepmbc.com (Im not sure if hes still making it)
Spool FMIC w/ larger Intercooler upgrade: $1125 http://www.spool-turbo.com/Mazdaspeed.html
Apex Cat-back exhaust: $550 http://www.apexr1.com/apmaprcaexsy.html
Apex MSP Cat-less Downpipe: $300 http://www.apexr1.com/apmado.html
HKS Super Sequential BOV: $215 http://www.spool-turbo.com/BlowOffValves.html
Mazda MIL Eliminator (CEL Fix): $21 http://www.apexr1.com/mamilelcfi.html
Autometer Full A-Pillar 2-Gauge Pod: $55 http://www.apexr1.com/augapo.html
Autometer 20 PSI Ultra-Lite Mechanical Boost Gauge: $45 www.jegs.com (part# 105-4301)
Autometer Electronic Ultra-Lite Oil Pressure Gauge: $54 www.jegs.com (part# 105-4327)
Copper NGK BKR7Es: $9 http://www.apexr1.com/ngkbkr7e.html
Urethane Engine Mounts: $127 http://www.protege5online.com/For_Sale_Page/AWR/awr.html
Akebono Ceramic Brake Pads: $62 http://www.apexr1.com/maprmpakcepa.html
Ground Control Adjustable Coil-Over Kit: $370 http://www.apexr1.com/grcokit.html
$61 Left over although I didnt add in S&H (wasnt in the rules! :D)
Disclaimer: I'm not promoting any specific company over another, I just went w/ easy links. I think that ION has some great stuff also, as well as many other vendors on this forum. These were just the easiest/cheapest to find real quick.;)
damn theifs!!! :D
Glad to see someone finaly ran with this idea (thumb)
Yeh thanks 1stmp3
By the way.. it's overall performance, not neccasairily straight line or twisties.. but maybe something in between... or one of the 2.. whatever u want ;p
1st MP3 in NH said:
:D
Yeah...I got my Injen on the way, so all I need is the $3500 to get all the goodies I listed. Plus, this gives me a good pick-list in the future. There are some things I listed I probably wouldn't buy (Ground Controls..I think stock is fine), but I wanted to spend the whole $$. Really, there's lots of flexibilty in there..which is why I bought this car. For less than $3000, you can make this a serious tuner...which still makes it far less than a stock WRX or EVO.
*realizes*-"oh s***, I could have put forged pistons on there"
OK here it goes: Mines gonna be for drag racing since I can't take corners.
-Manual boost controller- 45$
www.joepmbc.com
-Fuel cut defenser- 60$
www.joepmbc.com
-Front mount intercooler- 1000$
www.spool-turbo.com
-Carbon fiber hood- 799$
www.wingswest.com
-80MM turbo back exhaust- 589$ est.
www.cork-sport.com
-Co2 intercooler sprayer- 50$ HM
www.MAKE IT YOURSELF.com
-1 step colder plugs- 10-15$
www. CHEAP INSURANCE.com
-2 drag radials- 260$
www.bfgoodrichtires.com
-100-116 octane gas- 4.50-6$ a gallon
www. YOUR LOCAL TRACK.com
-Boost gauge- 41$
www.summitracing.com
-Intake air temp. sensor-205$
- Front and rear urethane motor mounts- 129$
can't think of the website
-Removal of all extra weight (subwoofer box, back seat, passengerside front seat, door panels, whatever else is easy for you to remove)- Free!!
www.DO IT YOURSELF.com
Boost- 14-15psi.
Front tire pressure 14-18psi.
Should get you mid-low 13's easy.
not including labor eh?...
Rods 700 bucks
www.pauter.com
Pistons 600 bucks
www.jepistons.com
arp head studs 120bucks
www.arp-bolts.com
Haltech e6X 1000 bucks
www.haltech.com
New Head gasket, rod bearings, etc for bottom end rebuild 200 bucks
Joe p mbc 45 bucks
Autometer boost gauge 35 bucks
www.autometer.com
pillar pod 50 bucks
www.autometer.com
Custom 3 in downpipe and exhaust 400 bucks
www.yourlocalmufflerstore.com
Hardpipes and front mount ( 975 bucks ion)
i know im over, but this would be cool
TOTAL 3945 bucks, well worth it imho
Then again if you throw labor in it gets a tad more expensive..:D
-B
OK, I would take the 3500.00 a use it as a down payment for an Evo...
Shouldn't you set goals and a $ amount instead of just the $ amount. Like say .92 or better skid pad, 1mph improvement in the 700ft slalom over SCC's testing, 13 second 1/4 mi, etc.
Anyone can throw $ and parts at a car but it takes a true tuner/enthusiast to make the best of those parts and money.
